03_Cobra_sb
Mar 29, 2015Explorer
Itasca Gray tank problem
I have a 90 Itasca class C RV. On the gray tank exit fitting, there is a gasket that goes over it and clamps down. There is no rips in the gasket and it started to leak. Noticed the gasket had slipped and I readjusted it and tightened it. No leak. Then after driving on rough roads it did the same thing. Is there a sealant you can use with rubber and the plastic tank that will hold the gasket in place? or any other ideas?
Thank you for your help.
Chris
Chris
