Here's some items on our Itasca that came on it new right off the dealer's lot in 2006. For Winnebago named models, at least some of these were listed as options. I don't know if the dealer had to order it this way ... or if some Itasca Class C models back then came with these items as standard, while Winnebago named models did not unless ordered this way:
- Double 12 volt batteries accessible, but isolated from, the coach's interior
- 12 volt electrically heated tanks for drycamping
- Automatic coach steps
- Bright aluminum running boards
- Crome wheel covers
- Heated and remote controlled cab mirrors
- Four wireless walkie-talkies mounted in an automatic charging rack
- Outside entertainment center with it's own independent roof antenna
- Weather band CD/FM/AM RV cab radio with both cab and coach speaker systems
- Engine/coach battery switch for the cab radio
- Spare tire, frame mounted
- Tire changing equipment
- Hardwood fronts on all cabinets
- Oven
- Two outside cabinets for long items like fishing poles, shovels, brooms, etc.
- All outside storage cabinets are steel with carpeted floors
- Outside shower
- Multiple and adjustable airconditioning ducts
- Multiple and adjustable heating ducts
- Rolled side edges on it's fiberglass roof
- Remote fuel priming switch for the built-in Onan generator
- Roof ladder
- Remotely switched 12 volt receptacle for TV
- 120 volt AC receptacles inside two interior cabinets for ?
- Special 12 volt receptacle for laptops and/or phone charging
- Vinyl gallery flooring, carpeted lounge and eating areas flooring
- Heat shields between the cab area floor and the exhaust system
