JK_Coney's avatar
JK_Coney
Itasca Spirit water heater issues
Bear with me. I have a new/old 2000 Itasca Spirit I just bought. I'm trying to iron out the kinks and get it on the road.
I turn the LP valve on. Flip on the water pump switch. Run the sink both hot and cold a bit. I flip on the heater switch. The light comes on. Then goes out, then comes on and goes out a few times, until it stays off. No hot water. I do have gas to the stove. The heater unit outside is cold. I know the former owner had it winterized, and all worked fine when he had it. Now a 1/2 hour later I get no heater pilot light at all. Ideas? Thanks!
  • If this RV has not been used in awhile, turn on the stove burners and let them run for 2 or 3 minutes on med to high. After you have done this, open the door to the water heater, leave it open and see if it lights. If it lights you can shut the door. If it lights it means you will need to adjust it. Is the water heater full of water? I flush mine out at the start of the season. Regards, Dick
  • Winnebago used Atwood, I know how that one works. What you are seeing at the switch suggests you have power to the controller board, connections to the switch, and at least part of the controller board is working.
    I'll let you borrow my basic diagnostic skills.
    Possibilities at the water heater:
    Gas valve not opening. You'll hear the clunk when it opens. No clunk, possibly a faulty valve, or controller or connections.
    Gas valve opens, but no spark. You can sometimes even hear the spark. Can be the sparker/flame sensor, connections, controller. If it is trying to spark, probably connections between controller board or sparker, or within the sparker.
    You get ignition, but it shuts off the gas after a few seconds. That is a flame sensor problem, in the controller, or connections to sparker/flame sensor. I had this problem when the high tension wire to the sparker had a discontinuity. The spark jumped the gap OK, but there was no continuity for the tiny low voltage current used for flame sensing. Needed to replace the sparker, a cheap mechanical part.
    Then the more basic problem:
    Maybe no gas supply to water heater, shut off at tank or air in the lines.
    Diagnostic skills at shops are sometimes problematic. Often they'll replace, or have you replace, the controller board, even though it seems to be functioning for other tasks. Apparently it is easy to replace and has a nice margin for the parts department. If that doesn't fix things, they'll start looking at things like maybe the sparker is defective, or the gas is not turned on. When they find something else to be the problem, they'll leave the new controller in, after all, they just sold it to you.
    Atwood DSI heaters do not use a temperature sensing device to detect a flame. After sparking for ignition, the controller applies a voltage to the sparker. If there is a flame, the ionized gases will allow a very small current to pass. Any excessive resistance, like a bad connection to the sparker, or a break in the high tension wire, will prevent the controller sensing this small current, and it will shut the gas off, then retry lighting a few times, then shut off for good.
    Atwoods do use a temperature sensor to limit how hot the water is heated. That's not in the flame path, it is in the side of the tank. That will usually not prevent the heater from lighting, but may prevent it from heating to a high enough temperature, if defective.
  • JK Coney wrote:
    DaHose wrote:
    Have someone operate the switch while you stand outside and listen for the pulsing of the ignitor? In mine, the electric connection on the gas solenoid valve is loose. So the ignitor pulses but the heater doesn't turn on. I can get it to work once on site, but I need to either permanently fix what's there or replace the solenoid.
    Jose
    What does the solenoid valve look like?
    The solenoid valve is connected to the gas input and looks like a cast piece with two cylinders on it about the size of a C battery. In general the function is as follows. When you click on the heater, the solenoids get voltage, open and let gas go through. The ignitor pops and lights the gas. If the thermister senses heat, the solenoids keep getting 12V and stay open. If it doesn't, then power to the heater is cutoff and the solenoids close, preventing a gas leak.
    Keep in mind my water heater is the original American Appliances 6 gallon. If my solenoids just die, then I will have to buy a new heater as I cannot get spare parts.
    Jose
  • j-d's avatar
    j-d
    Explorer II
    As a new member you may not know Chris Bryant. He owns an RV shop and is a great friend of this forum. On his webpage Chris has Troubleshooting and Service Documents. You may be able to find a service manual and help running down the problem.There are a couple water heater threads going on right now in Tech Issues.
    Even if two brands (Atwood and Suburban are the popular ones) function about the same way, they have different quirks and weaknesses. So it helps if you post Year, Make, Model of any component. If it's an ONAN generator, they guys need at least Model and Spec Code.
    Jose
  • Have someone operate the switch while you stand outside and listen for the pulsing of the ignitor? In mine, the electric connection on the gas solenoid valve is loose. So the ignitor pulses but the heater doesn't turn on. I can get it to work once on site, but I need to either permanently fix what's there or replace the solenoid.
    Jose
