MiRV
May 13, 2014Explorer
@spinners1
We had the same issue on our 2002 Sunova. I spoke with the Itasca folks and all of those cables were bundled and sprayed with expandable foam during installation at the factory. So it's not possible to "pull" new cable -- bad design if you ask me. I pulled as much up top and made a new connection…seemed to fix mine for now.
If you have a Fluke, you could isolate the exactly where the cable is bad…
So…the only way to do a fix is to run a new cable along a new path…best path is down from the antenna to the inside and back to a cabinet (if you can angle it properly from the top, would make it a lot cleaner installation). Then run the cable behind the various cabinets up to the front connection.
38,768 PostsLatest Activity: Nov 21, 2015
