Goldencrazy
Jan 27, 2014Explorer
Check out the older thread on the 30W and you will get a lot of info. I have a 30T and had a 30W. Yes it rides rough so I have modified at my own expense to overcome the fact it is light and on 19.5 inch wheels v. 22 inch of the next higher coaches like Sightseer. Have not had an issue with seeing dash. So here is the order of things to do that many of us have done to make it a nice coach. First you need a steering stabilizer. The best is the Roadmaster from general opinion but Steer Safe or Safe T Steer may be ok. Then a rear trac bar. Tiger trac from Blue Ox is good. I also changed shocks to Koni FSD and then added the Kelderman air ride and that is about 6 grand so you may not want to go that far. I was willing to pay for a great ride. Tire inflation is important. Don't over inflate. Most of us find around 80 works with the weight and can even do less on front. Finally the "Cheap handling fix", search for thread is great. It just requires moving the sway bar to tighter holes front an back. Let me know if you desire more info. Unfortunately it will cost some money to get the coach to where you want it. Sounds like your tires are way over inflated to get the float feeling. I now drive in 35 mph cross winds easily. The steering stabilizer is also a safety thing in case of blowouts you will track.
