Jim & Betty wrote:
OK I will take a shot at it a couple of thoughts from past experience from me and others.
You have a leak in the tank black or grey leaking into the sub floor. Co-worker had that problem.
The vent pipe is or has been pulled from the tank black or grey and is now venting into the sub floor.
The vent pipe is too short or was put together in more than one piece and that joint has come loose allowing gases into the wall or sub floor.
You have a vent issue where the tank pressurizes like an odd shaped tank where the levels in the tank block the vent causing the tank to pressurize. This happened to me I had grey water blow back through the bath sink.
You have a rotten potatoe in the pantry. :B
Your hot water tank has stagnated and is putting out hydrogen sulfide that does stink, long shot here because you do use the hot with the shower, assuming.
A battery that is going south will also smell up the place.
You have a dead animal in the heater vent at the bathroom
Good Luck
JimR
I'd like to add to this list,
Did some one take a leak in your shower when they were drunk?
Do you keep your dirty cloths in your bathroom?
Did you check your toilet down pipe by blowing into it? Let me know when you are going to do this so I can come watch, with gas mask in hand (-:........
Just had to get that off my chest! Seriously, all RV toilets have what is called a bowl vacuum breaker valve. Most of the time they are located internally inside the bowl structure to prevent, when opening up the (poop)drop valve, a big blow back into the coach and onto some ones bare bottom. They are not serviceable. The only way to repair them is to replace the entire toilet. Hard to guess how long they will last, use it more perhaps it will last longer or it may just wear it out! When I used ours less it failed in just a couple of years, when we lived full time it lasted 10 almost 11 years. Who knows the life of a toilet vacuum breaker valve until one can smell it! Nothing worse than making coffee in the morning and the smell of ones toilet be stronger than fresh brewed coffee!
Most of the time these valves are just little pieces of rubber laying over an opening. The opening or the flapper grows mold on it and fails to seal out the black tank smells. Yes, I know, no one likes to buy a brand new toilet, but some times you just have to bite the bullet and do it or tolerate that wonderful early morning smell when you first wake up that is not the wife's breath!!!!
