srx-6's avatar
srx-6
It's cold in the basement
On our last trip across central Florida the temperature on the lcd dash display showed 20 degrees F in our basement compartments. I do believe the temp sending unit has malfunctioned. I also think that this unit is located somewhere behind the white wall in the wet bay. Can someone point me to the location of this sending unit.
Thanks for any help
  • Executive wrote:
    Smarty, his rig is in his signature. Yours should be too. We can help you with that if needed... :B
    Mine is in the manabloc bay, passenger side second from the back in front of the rear axle, opposite the water pump assembly....Dennis
    Thanks Dennis, I will take a look.
  • Smarty, his rig is in his signature. Yours should be too. We can help you with that if needed... :B
  • would be helpful if you gave details of what your rig is
