msmith1199
Apr 24, 2015Explorer II
et2 wrote:
Over pressure can absolutely cause bad wandering. Our MH had 115 psi in the steer tires when we picked it up from the dealer. It was like trying to wrestle a bull driving it. After a weighing and determining the psi should be set at 85, everything settled down.
So as instructed the tires were set "cold" as they're suppose to be per the weight the rig is running at.
Now ours does have a constant pull to the right which I haven't been able to get figured out. Supposedly the alignment is correct and I have new shocks and tires are set properly. I think a blue ox Tru center in in our future.
Most all roads have a crown so your right hand side is almost always downhill from your left hand side. Doesn't affect cars a lot, but can have more of an effect on motorhomes.
