Executive45
Apr 24, 2015Explorer III
The tire inflation tables take the anticipated increased pressure into consideration. Set your tires at the correct PSI COLD. If you've set your tire pressure based on your axle weights, your wandering problem is unrelated to PSI....Dennis
