dougrainer
Nov 17, 2016Nomad
Both the 300 and 600 series will activate STORE while in transit without the parking brake ON. Your system already has Thermal Auto retract built in. IF the jack extends and once that happens the system has 30 seconds to auto Store(retract). IF after 30 seconds the jack fails to retract to satisfy the Down switch, your dash Alarm and Red indicator light comes ON. Odds are you have a defective RF cylinder that is slightly extending and then due to that heat fails to retract. Are you POSITIVE that after a normal STORE, that jack is fully retracted? Long shot would be a defective Down switch or switch wiring melted in the area of the jack/heat source. Doug
