ggrotz
Mar 25, 2020Explorer
jacks up or down
I have a 2005 samba class a.When I put it into storage is it better to put the jacks uo or down thank you.
SAR Tracker wrote:
If they are hydraulic cylinders (can you see a shiny shaft extended when they are lowered?) then they should be stored in the closed/retracted position. Otherwise, rust will form on the shaft, and when retracted after storage, will damage the hydraulic seals.
