- ernie1Explorer III have the Bigfoot levelers and the company says it is okay to store the jacks up or down since the shafts are stainless steel and don't rust. I always spray them well with a silicone spray as per manufacturer's recommendations.
- Johno02ExplorerOurs is stored in the drive with the jacks down to level it. We do spray the pistons with grease occasionally to help keep water off.
- doxiemom11Explorer IIOur hydraulic cylinders do not rust. We have been full-time since 2011 and sit from 4-6 months at any one time with the jacks down/extended. We have been within a mile of salt water and that didn't happen. This is not true. I would say, consult your owners manual or see if there is an answer on your manufacturers website.
- Yosemite_Sam1ExplorerMaybe needed down if storage is in specially high wind locations.
Found myself inside an RV with 50-70 mph wind and I have to put mine down even on a temporary stop. - SAR_TrackerExplorerIf they are hydraulic cylinders (can you see a shiny shaft extended when they are lowered?) then they should be stored in the closed/retracted position. Otherwise, rust will form on the shaft, and when retracted after storage, will damage the hydraulic seals.
- jdc1Explorer IIIt doesn't matter....they are leveling and stabilizing jacks. You don't need either if you aren't using it.
38,773 PostsLatest Activity: Apr 25, 2026
