tstryk
Oct 04, 2014Explorer
Jacks won't work
My leveling jacks won't work. It says "APPLY PARKING BRAKE" but it is already applied. Anyone have this issue?
tstryk wrote:dougrainer wrote:tstryk wrote:
I have looked for a loose switch or wire - I have air brakes, so no pedal for parking brake. Have pushed on the pedal hard, taken the air down to zero- set and reset the brake many times - no idea where the switch would be!
On Diesels, the AIR operated switch is close to the front firewall and the Steering Column area(outside, not under the dash). Doug
What will this switch look like? I have replaced some bulbous sensors before on an older motorhome - think they were for the low air buzzer. But the switch I am looking for would be in the same area?
