J-Rooster
Sep 14, 2016Explorer
wolfe10 wrote:Brett, when I had trouble with a Jake Brake happened several times I had to take the Jake Head valve cover off and replace a spool valve spring! Have you ever encountered this?
Easy to determine if the exhaust brake is working.
Down arrow to a gear-- 4th is a reasonable choice in most areas.
Accelerate to higher RPM in that gear.
Turn the exhaust brake on and off. Since the transmission is locked in that gear, it is a CONSTANT. If you don't feel additional braking, particularly at higher RPM, it is not working.
38,782 PostsLatest Activity: Aug 11, 2021
