giacomo3050's avatar
giacomo3050
Jay I slide out
I have a 2016 jay I Melbourne 24l the slide out when closed is touching at the topi both sides but on the bottom on the outside the right side is about an inch from connecting with the side of the rv. I also have a problem with water leaking from the lights between the visors
  • Thanks I live on the eastern end of Long Island there’s one rv sales and repairs within one hundred miles every time I call since November he’s always to busy
  • Slide outs can be aligned. Sometimes they were not tightened enough when initially assembled and since have misaligned after being driven 14,000 miles. You would think the slide out would drop, but not always.
    Another possibility is that if you have a wood floor, it might have been installed after the motor home left Jayco. The additional thickness of the wood floor could force the slide out that much higher. I believe the rollers of the slide out can be adjusted to compensate for the additional thickness of the floor.
    I advise to take your rig to someone who knows how to realign it.
    As far as water between the visors go. That is unusual. The water could be coming in from high above from the marker lights, or between the chassis roof and RV frontal cap above the cab dome light. If you don't know what to look for, have the repairman look at that too.
    One thing certain, you want both fixed right away because water getting inside is a very serious matter. It will do BIG damage, and but quickly. Not just structural, but also mold & mildew.
  • Just bought it. It has 14000 miles doesn’t jerk.just doesn’t come flush on the right side on bottom. If you go in the camper when it’s in the opposite side of the dinette touches the floor and the left side is up about 1/2 inch
  • Many possibilities.
    Does the slide move smoothly or does it jerk?
    Make any noises?
    Did it ever work evenly?
