az99 wrote:
RoWest wrote:
https://www.youtube.com/watch?v=jXMJrRQ3SVk
Why would you even make a video about how fast you can knock out a product.
Anyone should be able to figure out that a fast throw together time does not equal a good quality product. Jayco sure proved it by my unit also.
One thing you will note with ANY Dynamax is the build quality. I've been to the factory and they only work on a few units at a time. Probably because the demand is much less with the high sticker price. Coming from a Prevost, I will say that the materials and construction methods used in the Dynamax are head and shoulders above the competitors with the exception (maybe) of the Renegade's which are also put together well. I believe in the Dynamax "force" the materials used may be a step down from the XL but the build quality should be comparable since they run down the same lines.
