- pushtoy_2Explorergood thought STEEL RUBBER PRODUCTS good source
- 77rollalongExplorercheck with a company called steel rubber.. https://www.steelerubber.com/ and see what they have
- bobndotExplorer IIII have never done that but I would think you have to identify the type of seal and identify the mfg. of the slide. Put the slide out about 1/2 way and look at it.
Like a two sided bulb seal with a squeegee . It installs over the framework.
or a double bulb seal, with a bulb inside and one outside, those I think glue on .
2 places to start looking :
getrvparts.com
Trimlock.com - map40Explorer
IB853347201 wrote:
Ask Jayco?
Thanks, kind of obvious, already did. You have to go to your local dealer (RV One for us) and they are terrible, they want $500 when the seal might be $50 at most, and they can’t guarantee delivery date because if their shop need it they will use the one they got for you and order another. As the scam EVERYBODY into replacing the seals weather needed or not, the only way to get it is to have them install it. Pretty good scam, isn’t it?
Their national distributors also have high prices. I am sure somebody makes them for them and sells them for a couple of bucks per foot, not $20 per foot... - IB853347201Nomad IIAsk Jayco?
