huntdooly's avatar
huntdooly
Jayco vs Winnebago class A?
We are considering these two brands of mohos...in the short range, and wondered what people know about the differences in quality, ride, etc.
Thanks for your help!
  • Winnebago makes a nice MH, but based upon our search for a MH during the past year, I would suggest that you also look at motorhomes made by Newmar or Tiffin.
  • rr2254545 wrote:
    I feel that if you look at both the quality will be apparent - yes I am prejudice to Winnebago - but look for yourself
    Yeah, I gotta agree with rr2254545.
  • I feel that if you look at both the quality will be apparent - yes I am prejudice to Winnebago - but look for yourself
  • As good as the Workhorse chassis were, they are getting pretty long in the tooth. The difference in availability of Ford parts vs WH will only widen. Although Workhorse still exists in name, they are not the same company, now only making some electric vehicles. This can make a difference if you need some brand specific part while on the road.
  • Do some research on the Jayco motorhomes. One of their units in the 29' range received a lot of negative comments due to stability issues when on the road. In the same line, the 32' model seemed to be ok. Also, just do some general research regarding shorter wheelbase motorhomes being less stable, but it really varies by manufacturer.
  • If you buy a pre-owned Winne , you can get one with the GMC engine and workhorse chassie
  • All other things being equal, choose the floor plan you like. I believe the relative quality between these 2 manufacturers is the same. Are you planning in going on the road? If which determine which had s the best service network. My guess on that would be the Winnie.
  • They both use the same Ford chassis, same Ford V-10 engine, and same Ford Transmission.
  • In the short range, I prefer Winnebago...long range too.
