BB_TX
Sep 29, 2016Nomad
JimInMich wrote:
Rear brake lights/turn signals not working properly. I'm pretty sure it is a ground short of some type. The side clearance lights flash with the turns and dim out when the brakes are pressed. Front turn signals work fine.
Typical symptom of a bad ground. Tracing the wires may be difficult. Probably easier to just run a new ground wire from each rear light and attach it directly to the frame.
