Mile High wrote:
Does your coach have the switch that lets you combine coach batteries with chassis momentarily to give you a boost?
Yes, it does. Doesn't help with trying to start my engine. No change.
On further investigation today, I disconnected my chassis batteries, and both check out for voltage.
I must have a bad connection on the chassis side somewhere in my system? Or other suggestions to check out?
Anybody have this problem in past? My coach system appears to work fine.
I am connected to shore power (30 Amp), and my charger shows "float charging".
