Gene_in_NE
Mar 26, 2015Explorer III
goboborz - Just a little caution.:D If your chassis battery is really dead, making a connection between the two positive posts on the 2 batteries may create a sizeable spark. Be careful that you do not blow up a battery by igniting the battery fumes.
That is the reason it is recommended to connect the negative post of the good battery to some metal bolt on the dead battery vehicle. That keeps the sparks away from the battery. You cannot do that when the negative posts are already connected together by the steel frame of the RV.
38,780 PostsLatest Activity: Jul 04, 2015
