avanti
Mar 28, 2015Explorer
The other thing to keep in mind is that a boost switch can vastly increase your emergency-driving range in the case of an alternator failure (which, as failures of modern vehicles go, may be one of the more common ones). Indeed, if you have a genset, it can extend it indefinitely. If you vehicle has an isolation relay and adequate wiring, this mod is so cheap and easy that it seems like a no-brainer.
38,780 PostsLatest Activity: Jul 04, 2015
