Rwake901
Nov 05, 2016Explorer
cjoseph wrote:
They only recent problems I have seen posted are:
1. The bolts on the rear sway bar brackets aren't tight enough from the factory and work loose or even fall off. If you have handling problems, check that first.
2. The brake light and ABS light come on in some of the 2016 or newer models. Ford has a TSB for a re-flash that fixes it.
Other than that, like said --bullet proof.
I was under ours changing oil two weeks ago when I noticed one of the sway bar brackets on the back was broken and most of it was missing. I was wondering if it came loose or if the bolt broke. Now I guess I know.
