Lt46
Jul 20, 2014Explorer II
Your jacks will lift the tire well off the ground BUT....be very carefull crawling under without using other jack stands for support...if no jack stands use 4x4 cribbing. Also, any time you lift the rear wheels off the ground you are in very dangerous territory. The E-Brake is attached to the driveshaft, just aft of the tranny. Lifting the rear wheels mean no E-Brake holding the moho. It will roll and it will be costly in repairs and hopefully not in injuries. In fact, I carry a few 2"x 10"x 5' pressure treated boards just for raising the rear wheels without losing contact with the ground.
