murphy8's avatar
murphy8
2004 winnebago adventurer
2004 winn adventurer
workhorse chassis 8.1 vortex
when under 30 degrees transmission wont shift starts out in 2nd gear i believe. if i drive a mile or 2 shut it off and restart it shifts fine. this always does it when cold,then i can drive all the way to florida with no problems. ive had rv for 8 years .but im leaving later this winter when its sub zero. im afraid it wont warm up enough.
any clues thankyou
  • you can email me at allbrandauto@aol .com I can walk you through your problem
  • 2nd gear is a default mode you have a electrical problem maybe a shift soliniod maybe the trans. control module you need someone that has a scanner most automobile repair shops will have a scanner that has workhorse software
  • After 21 years of service, seems time for pro to examine your transmission.
