jspringator
Oct 18, 2015Explorer
Thanks. I ran the VIN number and it shows P-30. It looks like the chassis must be closely related. I'm going to cut a straw 2" and measure between the bumpstop and what it impacts on the lower bumpstop, then have it aligned. I'll assess the situation and determine whether an improvement in the sway bar is necessary.
I'll also have them check the bell cranks for play.
I was checking the front tires. There are bumps evenly spaced on the edge of the tread of both tires. Chinabombs. I'm lucky I made it home. Michelin XPS RIB?
