jspringator
Oct 19, 2015Explorer
Airbags held 70 pounds overnight. I ordered a remote hose for checking and adding air. We'll see how they do in the upcoming weeks. I don't want to replace them if they hold air. The bag that was flat has the schrader valve off center. I think I need to fully inflate to straighten it out and then deflate.
The expensive bell crank is ordered. So is a set Bilstein shocks for the front. Instead of a new sway bar I'm going to start with new Poly bushings. I'll probably go on and get a rear Roadmaster tracbar.
Looks like 6 tires are needed too. If I'm replacing the rear tires should I also replace the rear shocks? I don't want to ruin the new tires.
