jspringator
Oct 25, 2015Explorer
Here is where I am on my 2002 Winnebago Sightseer 27c (Workhorse (P30-32). 4 Bilstein shocks, rear trac bar, airbag filling valve extensions, Roadmaster steering stabilizer with spring, Henderson Bell Crank, front sway bar extensions. I'm also going to add teflon lined stainless steel brake lines, and tighten up the steering box. When all that is done, I'm going to add 6 new tires. The Firestones are reasonably priced, and can be installed locally. Once the tires are installed, I'm going to experiment with airbag air pressure. When that is selected, I'm going to take it back for an alignment.
This is a little bit more expensive project than I anticipated, but when it is all said and done, I hope to have a safe well handling motorhome for a fraction of the cost of a new one.
