Walaby wrote:
goufgators wrote:
Ivylog wrote:
Buy a 50 to 30 adapter and a 30amp cord...back to the good old days and problem solved.
Such a simple but workable solution! Thanks for the reply...
Wouldn't drawing 50 amps over a 30 amp cord potentially over tax the 30 amp cord?
Mike
You are correct, the use of a 50 to 30 amp adapter, to use a 30 amp cable to feed a 50 amp panel is a very bad solution. You could be potentially drawing 50 amps over a 10 gauge cable. P:S
Best solution is using SOOW 6/4 cable! Soft supple and will carry the load!!!!
