- Passin_ThruExplorerI am curious, Whats a bunge cord? One for a bung on a Whiskey barrel?
- debandiExplorerI would use a gas piston similar to the ones found on many camp trailers. It keeps pressure on the door keeping it open. These pistons come in different sizes. Good luck
- Executive45Explorer IIIVice grips or a simple spring clamp (get it in color to match the coach) depending on how worn the dimple is....Dennis
- Bruce_BrownModerator
GordonThree wrote:
I'm curious, what does a diesel motor have to do with the problem?
Simple, because they use a completely different door set up than a gasser does.
Ours worked great for years then started doing the same as the OPs. In our case the bushing had worn out. I spun a new one out on my lathe and installed it. Fixed. - DaveG39ExplorerI had that problem, called the door manufacturer (name on door decal) and they sent, for money, a replacement scissor mechanism for the top of the door. Short time to remove old and install new.
- GordonThreeExplorerI'm curious, what does a diesel motor have to do with the problem?
- 352Explorer IIHave the wife keep tension on it
- LwiddisNomad IIII come up with RG’s idea too....bunge cords. Might work on a gasser too.
- accsysExplorerA pair of vice-grips squeezing those two arms at the top of the door will do the trick. You can also rough up the little dimple on those arms so it isn't as smooth but the vice grips work best.
- IvylogExplorer IIIIt's a 2013 Phaeton 36GH...one click away under his profile. Still no help for me as I have no idea what kind of mechanism it has for holding it open. IF it's a arm like a scissor I've had good luck bending the short portion after the pivot so the dimple on it goes into the depression on the other portion with more force. I use two large crescent wrenches...others have used a large backing hammer on the bottom of the pivot while hitting the top to tighten it.
38,778 PostsLatest Activity: Jun 06, 2026
