The OP has a 2008 Winnebago Vista 30B, so unless someone in the past has replaced the converter, it is a single voltage battery boiler that Winnebago installed.
The OP, probably with some help, can determine the make//model of the converter and then decide if it is single stage or multi-stage.
If Multi-stage, you probably only need to check the house battery water a couple of times a year, If single stage, then you need to watch them like a hawk and check them monthly or more often.
I didn't keep my View plugged in constantly until I changed out the converter, now it stays plugged in 24/7. The fridge is turned off, but yes, the board still receives power, in addition to other items. Not sure how much that shortens the life span of such equipment, if any.
Looking at the wiring diagrams for the OP's MH it appears to have the same power panel/converter that my View does, most likely a Parallax single stage converter, which the OP would do well to swap out for a Progressive Dynamics 4645V which is an easy direct out/in swap.
http://www.bestconverter.com/PD4645V-45-Amp-Converter-Upgrade-Optional-Remote-Pendant_p_351.html#.WmEuH66nGJAIf OP posts a pic of the electrical panel with the door open. and cover removed, it would help. Otherwise you have a bunch of personal experience comments that may or may not be of value to the OP.
Charles
