Two thoughts.
First, I agree with others about using Reflectix - with one clarification.
I did cut Reflectix for every window, except the windshield, and that did help. Those pieces were installed on the inside of the glass - cut to fit, so they stay in place. But, when I then added Reflectix to the OUTSIDE of every window that received direct sun, what a difference. (Inside only, the glass still gets HOT; buty add it to the outside, and the glass does not get hot.) So, now, when we're home, and it's summer, not only do I put the interior Reflectix in place, but the outside as well. I attach the outside with painters blue tape - and yes, occasionally i need to replace the tape - but it sure does work. Also, for the exterior Reflectix, I "tape" the edges with aluminized tape (2" wide tape), so weather tends not to be an issue.
I'm so happy with the exterior pieces, that we do take them with us when we're in the southwest, or similar, in summer. Put 'em on when we stop for the day, take 'em off at dark.
Second, when at home, we plug our '08 PW Lexor into a 20 amp circuit. We leave the A/C on in summer, and put an oil filled heater inside over the winter. So, for the life of our PW - when we're at home, it's never been below about 40 degrees inside, nor over 90 degrees. We do leave cabinet doors and drawers ajar.
Both high and low temps will take their toll given sufficient time. I'm just trying to make our PW last 'til we don't want the wheels to turn any longer.
Cheers.
