OFDPOS
Jul 12, 2015Explorer
Johno02 wrote:
fill with city water. get an empty plastic bottle and fill it at the same time. place capped bottle on counter inside rv. leave it there till you return. is water in bottle is OK, then tank is OK. drain and refill before you leave to fill with fresh treated water. use just as you would tap water at home.
In this case make sure and put an open vent to the "caped" plastic bottle of water , after all the fresh water tank has open vent ;)
38,782 PostsLatest Activity: Sep 10, 2026
