timmac wrote:
Monroe RV shocks are also smooth and cost less, I went from Bilsteins to Monroe's and there was a difference..
Give them a try..
Part of the Kelderman front end install is to replace the shocks with the Monroe Shocks. They are so much softer and as they point out cheaper than Koni. They of course also change the leaf springs and sway bars and add the air bags so it is a new front end suspension and makes a huge difference. For those who have the rear installed it is simpler as they just add the bags at the shackle but you must have the room for the addition and my coach had the water heater and tank in the way. It appears I didn't need the rear with the front improvement.
