- J-RoosterExplorer
Nutinelse2do wrote:
X-2,on Cali.
I use the California King size for our 72 x 80 bed. - codelldExplorerCheck the following for exact size sheets.
http://www.ablifestyles.net/sheets/ - StuartTExplorerBig Katuna, I went with your suggestion and ordered a set from Camper King. Didn't know that option was available.
Thanks for all your feedback. - pipers_familyExplorerRegular king sheets are usually square 78x80 on fitted. I would use Cal king. JMHO
- Big_KatunaExplorer II
StuartT wrote:
Big Katuna wrote:
RV kings are all over the map. Some are 72 x 75. 75 length is not uncommon in RV beds.
Best to measure.
I did. It is 72 x 80.
Then I'd get on EBay or Amazon and buy a 72x80 RV KING set from Camper King. - Nutinelse2doExplorerI use the California King size for our 72 x 80 bed.
- AprilWhineExplorerI bought a flat sheet and tucked it.
- StuartTExplorer
Best to measure.
I did. It is 72 x 80. - Big_KatunaExplorer IIRV kings are all over the map. Some are 72 x 75. 75 length is not uncommon in RV beds.
Best to measure. - IvylogExplorer IIII would go with the longer if you are tall and the wider if normal height so the bottom is less likely to move (more under the mattress) when you roll over.
Or you can buy one of each and report back.:B
