Bucky1320
Aug 25, 2014Explorer
Kitchen Drain Hose/Slide out
I don't know the wisdom of putting the kitchen on the slide, but my 99 Harney Renegade pusher has just that. It's new to me. I fixed a kink in the drain hose, only to find a split lower down. Fooey!
As far as I can tell, I have to work through the drawer openings, which means everything is one handed.
First question: Is there anything I should be doing to make this easier? It almost looks like I can do some of it in the basement, but the stuff in the slide is crazy difficult. I don't see an easy way to remove the side of the sink base.
Second: There seems to be a slot that they expected the wire reinforced hose to go through and stay lined up with. Is there a good method for keeping these from kinking or splitting? Is there another material I should be using?
