garry1p
Apr 05, 2017Explorer
I had that problem several years back turned out to be the four wire connector was corroded and would not pass enough current to run the motor.
The connector looks like the four way trailer connector take it apart spray contact cleaner on both sides reconnect then do it again.
Caution when working on the steps if they suddenly start and you are in the way the steps will win that battle every time.
I have also had to replaced the motor but that was a different symptom.
