- Francesca_KnowlExplorer
spdrcr wrote:
i dont know, but it would have not broke the deal, im buying it wether or not it fits, ill build another garage if i have to, i have the room. its the coach i want. dam another garage.
:B
That's the spirit! - spdrcrExploreri dont know, but it would have not broke the deal, im buying it wether or not it fits, ill build another garage if i have to, i have the room. its the coach i want. dam another garage.
- MNtundraRetNavigator
spdrcr wrote:
no, im getting it dec 10, the specs i found on the internet say with a/c on top 148 inches, wich is a hare over 12ft, but i also read sometimes specs are not correct.
That's why you should have had someone actually measure it before purchasing it. Easy enough to do. Use tape measure for reading from roof to the ground when drivable. Tape measure the highest item on roof (high point to roof). Add the two figures together for the full height. You would have to trust the person doing the measurement if you did not go there before purchasing. It's still your problem after getting it home.
No one to blame except yourself if it does nor fit. As always: "Buyer beware"
Also; Have you actually measured the opening height with the door open? Is that opened height always at least 12 feet throughout the length inside the garage? - spdrcrExplorerdont have the coach yet, but yes from the specs its not lookin like it will
- Mich_FExplorer
spdrcr wrote:
does anybody know if my 2008 fouwinds kodiak 32b super c motorcoach will fit in a 12ft door?
How high is it? :R
According to these specs no
Nobody here knows what that particular MH might have on the roof. - spdrcrExplorerno, im getting it dec 10, the specs i found on the internet say with a/c on top 148 inches, wich is a hare over 12ft, but i also read sometimes specs are not correct.
- 2oldmanExplorer IIHave you measured it?
