John_Joey
Apr 27, 2018Explorer
One more thing you can do is with 3/4 tank of gas just put the line in a jar on the ground and put a pull on it. The line should then siphon gas naturally. Take a look at that stream. If it appears strong then back to square one. If not, then you could just replace the line with a splice as far back as it is easy to get too, just too see if you get a stronger stream when you do a pull on it. Who knows you might get lucky and cut out the bad section.
