Gjac's avatar
Gjac
Explorer III
Sep 08, 2021
Kohler 5CKM21 no compression in both cylinders
Finally got to go camping last week, started the genset to heat lunch, it started right up, ran for no more than 10 mins then died. Would not start again. Checked fuel pump plenty of fuel squirted out, checked spark had spark but plug was dry. I noticed a broken wire to the fuel cut off solenoid at the bottom of carb bowl and reattached it thinking that was why the plug was dry but still no start and dry plug. Sprayed starting fluid into cylinder but not even a pop. When I returned home I checked both cylinders and neither had compression. What would cause both cylinders to have no compression? Of course my worst fear is a broken cam shaft or something serious, but I did not hear any noises when the genset died.
