wildmanbaker
Apr 29, 2018Explorer
This will not fix the problem, but it may help isolate the problem. If you have access to compressed air, take the gas cap off and try blowing into the fuel line to the generator with the air. There should be enough room to get up underneath and see the top of the tank to see if there is dust blowing from the line anywhere. It will also verify that the line is not collapsed or plugged. What John and Joey said applies.
Good luck.
Good luck.
