wildmanbaker
May 02, 2018Explorer
I honestly do not know how the electronics on you generator work. If they feed to the pump is through a relay, the relay may be going bad, and after a while it does not stay locked in. Otherwise, it may be you will have to drop the tank enough to change the fuel line, as it may be closing during use.
Is your MH front end all good now?
