John_Joey
Jun 23, 2015Explorer
Generators aren't my thing, but I did have that one and know a little about it. It does have a low oil pressure switch which might be the problem if either you have low oil, or the wrong grade of oil. Like the prior post said, do the simple stuff first. Change the oil and verify the correct grade is going into it. Possible that the oil pressure is fine until it heats up.
