tpi
Sep 15, 2015Explorer
These rigs like to have the tires set by weight, not some generalized 75-80 PSI don't they? I used to overfill a bit so I didn't have to add as often. Now I keep it in a narrow range because the lower it goes, the better it feels. Front helps the handling and rear helps the ride. Mine being only 11400 lbs and having both oversized sway bars really hits bumps hard with the 75 PSI+. My trigger (add air) point on front tires is only 50 PSI. When it's at that point, just before getting out the compressor, it feels sweetest.
