Gdlow wrote:
I heard these were much smoother running so ordered and had installed them...they are as hard riding as the Bilstein's...Can they be softened Up???
Not all folks who've installed the FSD's on their coaches experience any ride improvement however we sure did on our Ford Chassis.
If your's is a workhorse it most likely came with bilsteins. Just curious, how much air pressure in your tires?
Depending on the load range of your tires, and the weight of your coach, you may be able to lower the pressure, however it's important to get your coach weighed first, then based on axle weight check the tire manufacturers "Load Inflation Chart" before reducing any air pressure.
Good luck in softening up your ride and keep us posted on your progress..
Safe travels..
