What Brett suggested is true. You want to be careful increasing the spring rate on one side, especially on the front. Unbalancing the spring rate is helpful in a race car that only turns left, but not recommended to one that is required to turn both left and right.
If the difference is great enough to require a spring leaf be added to level, you should locate a spring company and explain the problem, and have them make a new set, if they will do it.
