et2ExplorerJul 02, 2014Koni shocksI'm trying to refine my 1 year old MH handling. It's alignment has been checked, tires adjusted for weight, ride height adjusted. Most of the wandering is gone, the only significant is the constant le...Show More
wolfe10ExplorerJul 02, 2014I like FSD's as well. For the "constant left wheel correction, I would have caster checked.Right caster should be equal to right PLUS about .75 degrees. This will help compensate for road crown.Assume you have checked for the common things:brake dragswapped front tires left to right
Related ContentNew shocks- Koni or Bilstein?Koni FSD ShocksUpDate : Koni FSD ShocksKoni FSD shocksKoni vs Bilstein shocks
