lryrob9301 wrote:
Yes, you need to update the programming using the flash update wizard, and it needs to be powered by the 120v converter instead of running off 12v coach batteries.
You are also correct, KVH technical support is virtually worthless.
Your right about KVH, and might be low voltage by what you say, when I hook up pc to 9 pin main board nothing is coming across screen but can put in commands ? I typed in SATINSTALL,TRISAT,DISH
went to pinging for sats and came back with 56000 No Carrier? Restarted system power several times, keeps saying waiting for reset ? Must be another power source to a fuse Im not finding outside of the wall switch, but getting a 12 VDC 5 amp AC/DC power supply to see if thats the problem, low voltage? Thank you very much for your input, Ron & Corinne
