twobags
Mar 22, 2014Explorer
KwiKee Electric Steps
I have a 2004 Allegro with KwiKee steps that will not retract with the step sw. , the door closing or the ignition bypass, has anyone else had this problem ?
tiredkid wrote:Jagtech wrote:
As mentioned, most folks vote for a bad controller. But before spending the $$$, try tapping the motor with a (small) hammer while its trying to close. If it operates, then the motor is bad. Also check for a bad ground on the controller, they are known for causing issues. And as noted, keep hands and arms clear!
as said already try putting 12V directly to motor if it works then its controller or switch magnet
