twobags
Mar 22, 2014Explorer
KwiKee Electric Steps
I have a 2004 Allegro with KwiKee steps that will not retract with the step sw. , the door closing or the ignition bypass, has anyone else had this problem ?
Jagtech wrote:
As mentioned, most folks vote for a bad controller. But before spending the $$$, try tapping the motor with a (small) hammer while its trying to close. If it operates, then the motor is bad. Also check for a bad ground on the controller, they are known for causing issues. And as noted, keep hands and arms clear!
